Reg. routing issue
Hi halijenn / pkampana / all
I have an issue where there are overlapping networks at inside and outside of ASA hence is it possible in the ASA that i can segregate the traffic by means of routing or NATTING ?
(192.168.16.0) Router (at WAN Branch) -----Switch ---(Outside)ASA(Inside)----Switch ----Router1----Router2 (192.168.16.0)
  • Firewalling
1 ACCEPTED SOLUTION
Re: Reg. routing issue
Ankur,
I had answered a similar thread a while ago. Spent quite a bit of time coming up with the lines that he needed. Unfortunately he decided not to implement.
You can read here: https://supportforums.cisco.com/message/3046434#3046434
Refer this link: http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/nat_static.html#wp1082664
-KS
yes, you can do it by NATing subnets.
One of the ways to do it is with outside NAT:
Possible orther include policy or straight static NAT.
Marcin
Ankur,
-KS
thanks a lot kusankar & Marcin !
161
