regular translation creation failed for protocol 47
                   Hi Everyone,
We have external user on dmz and he is trying to connect to their company network over VPN.
HEre is log from internet firewall
i can see  the firewall is allowing  the rule.
%ASA-6-302013: Built outbound TCP connection 6931561 for outside:200.x.x.x
%ASA-3-305006: regular translation creation failed for protocol 47 src dmz 192.x.x.x
What should i do to fix this issue ?
MAhesh
1 ACCEPTED SOLUTION
Re: regular translation creation failed for protocol 47
The problem is that GRE is portless. It is just an IP protocol. Not something that we can PAT using a TCP/UDP.
You can try this command. This will add PPTP to the global inspection.
fixup protocol pptp
If this doesn't work an static nat for that host should be required.
Luis Silva
"If you need PDI (Planning, Design, Implement) assistance feel free to reach us"
http://www.cisco.com/web/partners/tools/pdihd.html
Luis Silva "If you need PDI (Planning, Design, Implement) assistance feel free to reach us" http://www.cisco.com/web/partners/tools/pdihd.html
fixup protocol pptp
Luis Silva
Hi Luis,
Thanks for reply.
I added inspect pptp under global inspection policy and after that ASA  allowed GRE  tunnel.
Seems pptp is not inspected  by default.
Best Regards
Mahesh
Yes you are right it is not .
I am glad it helps.
Luis Silva
2466
