Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Remote license upgrade on Failover pair
Hello all,
I need to upgrade the licenses on a failover pair remotely and have a few questions. I was following the guide at:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00806b1c0f.shtml
but it doesn't seem to have gone exactly to plan. The first 2 points state the following:
  1. Upgrade the license in primary and do a write mem to save the configuration.
  2. Now shut down the primary (do not reboot). This will make secondary active. Do not remove any of the cables throughout the upgradation process.
The problem I have is that when applying the license upgrade to the primary, the failover pair was broken do to a difference in, well.. licenses. This means the secondary wont go active if i shutdown the primary.
I'd like to know whether it is safe for me to simply apply the identical license to the secondary device and reactivate failover remotely. The primary currently has around 30 L2L VPNs terminating on it so I can't risk it crashing/hanging or generally incurring any downtime when I reactivate failover.
If anyone has any insight it would be much appreciated.
On a similar point, I activated failover remotely on another pair a few weeks back and they both crashed before config was replicated. Admittedly this was using the management interface for failover, but all config had been cleared so it has left me a little hesitant.
Thanks in advance,
Chris
Re: Remote license upgrade on Failover pair
Pls. read this thread.
https://supportforums.cisco.com/message/2008230#2008230
We are still working on getting Cisco document (docId=70390 ) corrected based on the problems faced for a few of them in the above link.
-KS
Community Member
Thanks, I had searched before hand but somehow missed that thread...
177
