Remote service implements TCP timestamps
I trying to stop the RFC 1323 Timestamp leak (Nessus ID 25220), I have add the following commands to our PIX firewall. Test still comeback positive.
access-list 100 deny icmp any any timestamp-request
access-list 100 deny icmp any any timestamp-reply
icmp deny any outside
icmp deny any inside
Everyone's tags (4)
1 ACCEPTED SOLUTION
Re: Remote service implements TCP timestamps
You are dropping icmp timestamps. You need to clear the TCP timestamps.
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/conns_tcpnorm.html explains how, and the config will look like
tcp-map tmap
  timestamp  clear
access-list tcp-acl permit tcp any any
class-map tcp-class
  match access-l tcp-acl
policy-map pmap
  class ts-class
    set connection advanced-options tmap
service-policy pmap global
Let us know if it helps.
PK
tcp-map tmap
  timestamp  clear
class-map tcp-class
policy-map pmap
  class ts-class
PK
Solution worked, thanks.
tcp-map tcp-map-timestamp
tcp-options timestamp clear
class-map class-map-timestamp
match any
policy-map policy-map-timestamp
class class-map-timestamp
set connection advanced-options tcp-map-timestamp
service-policy policy-map-timestamp global
That is good news!
Please mark the thread as Answered so that others can benefit in the future.
Take care,
PK
Hi hope everyone is fine.
It didnt work for our case. Our vendor simplified to command and after implementing it I still get the TCP timestamp vulnerability for hosts behind the FW. Is this command suppose to clear all TCP timestamp request for hosts behing the FW or is it simply just for the FW?
tcp-map tmap-timestamp
policy-map global_policy
class global-class
  set connection advanced-options tmap-timestamp
Hope anyone can shed some light on what we did wrong or an alternate solution.
Mon
3165
