Remote VPN on ASA5520 problem ?
samart_sri
i create remote vpn on asa5520 to inside its work, i can use resource (server) in inside ok but i can't ping to firewall's interface inside. and when i add static nat on asa5520 when i remote vpn it's cann't work i cannot use resource(server) in inside. please help me
husycisco
Level 7
Level 7
Hi Samart
You can not reach inside interface of ASA from outside by default for security purposes. You should set management access in global configuration.
management-access inside
Also inspect ICMP traffic
policy-map global_policy
class inspection_default
inspect icmp
