02-15-2012 04:00 AM - edited 03-11-2019 03:30 PM
Hi All,
Users are able to connect far end network using cisco vpn client.
Even ther are able to access url of far end network ,But the problem is ther are not able to fetch the data from there server.once they connect to network.
So what might be causing the problem. Is this the problem of far end.
02-15-2012 06:02 AM
Please make sure you, that you have a static-route is in place on the inside network to push the remote-vpn ip dhcp-scope network-segment is to be pushed to FW's inside address. So let assume that FW's inside ip address is: 10.1.1.1 and "remote-vpn ip dhcp-scope" is 192.168.0.1/24, so your route would look like" ip route 192.168.0.0 255.255.255.0 10.1.1.1.
I hope that helps.
Rizwan Rafeek
02-15-2012 06:15 AM
Hi Rizwan,
Users from our company are accessing client network through remote vpn pcf file provided by client.
There are able to connect to their network through vpn but when they are not able to fetch the code from there servers .
02-15-2012 06:27 AM
"they are not able to fetch the code from there servers ."
Are the remote-vpn users able to ping the servers on the inside network of the client?
"fetch the code from there servers ." Can you be more descriptive about the issue, as not enough information?
02-15-2012 06:39 AM
There are able to ping the servers once they excute the command they are not able to fetch the code.
