Replacing the IPS module with a 4 port module
I am replacing the IPS module that is currently in my 5520 and was looking for some confirmation that there is nothing I've overlooked. The one area I am not certain on is whether I need to run a hw-module module 1 reset command at some point.
Here is what I have planned:
1.     Disable the service policy
2.     Run the command:  hw-module module 1 shutdown
3.     Power down the ASA
4.     Replace the IPS module with the new 4 port module
5.     Power on the ASA
Will the ASA recognise the new module and simply bring it up, or are their steps I've forgotten? It has been a long time since I installed the IPS module and can not remember if there was anything else.
Appreciate any input. Thanks.
Steve Green
  • Firewalling
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
That should cover it.
Assuming you're adding a 4GE-SSM, the 5520 should automatically recognize it at bootup during the power-on self test (POST). Once the software finishes loading, you should now have the additional interfaces available to configure.
Installation Guide.
Installation Guide.
Yes, the module is the 4GE-SSM, I figured it was that easy, just wanted to make sure........thank you for the response.
You're welcome.
Please mark your question as answered and rate helpful responses.
88
