required firewall product
hi all,,
for the following scanrio is there any firewall appliance is available?
i am attaching the diagram
Hall of Fame Super Silver
A network firewall does not enforce user level privileges (for example read vs. write access) on applications running on servers. That needs to be done on the server applications.
A firewall can restrict what addresses (or even what users if you use identity firewall features) can reach the servers and what protocols they may run (for example, https only etc.).
hi marvin,
thanks for your explanation.
this is just the requirement from my client i also explained same which you mentioned.
i thought may be something else will be there that why i put in the forum. may be i will get some informtion like you good firewall guys.
107
