Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Required OID number to Monitoring Current host count
Hello all .
I can get the current host count running below command .
sh local-host connection
Detected interface 'outside' as the Internet interface. Host limit applies to all other interfaces.
Current host count: 10, towards licensed host limit of: 50
I need the Device OID which holds that information under system MIB's  .
Kind Regards
1 ACCEPTED SOLUTION
Unfortunately, the ASA does not have an OID for these stats.
Sincerely,
David.
Sincerely,
David.
Thank you is there any way i can check the same status on the ASDM ?
Unfortunately, no.  ASDM does not provide this capability natively.  You can use the CLI interface within ASDM, but I don't think that is what you were looking for.
Sincerely,
David.
227
