Resolving DROP during port forwarding
I am attempting to port-forward on an ASA 5500 to internal host .100. The outside interface recieves its IP via DHCP. Packets are being denied so I ran packet-tracer and get the following error from outside to ssh port on internal host.
Any tips on why this might be occuring?
#packet-tracer input outside tcp 79.x.x.x 1025 71.x.x.x ssh
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   71.x.x.x   255.255.255.255 identity
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: NP Identity Ifc
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
# sh run nat
nat (inside,outside) source static any any destination static VPN_NETWORK VPN_NETWORK no-proxy-arp route-lookup
nat (outside,outside) source dynamic VPN_NETWORK interface
object network obj_any
nat (inside,outside) dynamic interface
object network VM
nat (inside,outside) static interface service tcp ssh ssh
# sh running-config object
subnet 0.0.0.0 0.0.0.0
object network VPN_NETWORK
subnet 192.168.1.0 255.255.255.192
object network VM
host 172.16.0.100
# sh nat
Manual NAT Policies (Section 1)
1 (inside) to (outside) source static any any   destination static VPN_NETWORK VPN_NETWORK no-proxy-arp route-lookup
    translate_hits = 0, untranslate_hits = 0
2 (outside) to (outside) source dynamic VPN_NETWORK interface
Auto NAT Policies (Section 2)
1 (inside) to (outside) source static VM interface   service tcp ssh ssh
2 (inside) to (outside) source dynamic obj_any interface
    translate_hits = 61918, untranslate_hits = 8178
# sh access-list
access-list cached ACL log flows: total 0, denied 0 (deny-flow-max 4096)
            alert-interval 300
access-list dynamic-filter_acl; 1 elements; name hash: 0xdb693454
access-list dynamic-filter_acl line 1 extended permit ip any any (hitcnt=77285) 0xe1bfda1d
access-list VM-IN; 1 elements; name hash: 0x57079372
access-list VM-IN line 1 extended permit tcp any host 172.16.1.100 eq ssh (hitcnt=5) 0x5dc27602
Everyone's tags (4)
Re: rfp-check results in DROP during port forwarding
Can you post the full packet tracer output ?
You should been doing it to the outside interface of your ASA Ip address, can you confirm it ?
Julio
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Updated the orginal question with the full packet-trace.
Hello Vindemiatrix,
As I said on the previous post, the packet-tracer is wrong.
The packet created from host  74.207.x.x will need to go on port 22 to the outside interface of the ASA witch I think is not
172.16.1.100.
Please do the packet tracer like this and everything should work as you have  this properly configured.
packet-tracer input outside tcp 74.207.x.x 1025 x.x.x.x(Outside interface) 22
If this post helps you, do rate it!!!
Julio
Updated question for claified response.
Can you share the show run access-group?
Also just to confirm  71.x.x.x is the outside interface ip address right?
Julio
The problem was with:
per:
https://www.cisco.com/en/US/docs/security/asa/asa84/configuration/guide/nat_rules.html
(outside) to (outside) after-auto source dynamic VPN_NETWORK interface
So now everything is working.
Good to hear that,
Julio
1680
