Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Reverse DNS Issue with Barracuda Spam Filter
Hi, I have a Barracuda Spam Filter which accepts our incoming smtp and passes it on to our Exchange Server.
For Outgoing emails the Exchange server sends directly out.
I have static Nats set up as follows (external IP's replaced)
Exchange Server
static (INSIDE,OUTSIDE) 1.2.3.4 10.0.0.5 netmask 255.255.255.255
Barracuda
static (INSIDE,OUTSIDE) 1.2.3.5 10.0.0.6 netmask 255.255.255.255
also access-lists as follows
Exchange (https & www for Outlook Web Access)
access-list OUTSIDEIN extended permit tcp any host 1.2.3.4 eq https
access-list OUTSIDEIN extended permit tcp any host 1.2.3.4 eq www
Barracuda (incoming SMTP)
access-list OUTSIDEIN extended permit tcp any host 1.2.3.5 eq smtp
Problem is when I send emails out, it goes out as 1.2.3.4 which does not match up with the MX record that points to 1.2.3.5
Therefore we are receiving Reverse DNS failures from recipients
<exchange1.ourdomain.local #5.7.1 smtp;550 5.7.1 Client host rejected: cannot find your hostname, [1.2.3.4]>
Is it possible for our Exchange Server to send out via 1.2.3.5 ? (I cannot use the Barracuda as an outgoing relay)
Chris
Re: Reverse DNS Issue with Barracuda Spam Filter
Chris,
Create a reverse static route for the Barracuda. currently sounds like you are using a global NAT for all Inside IP address, try the below:-
static (outside,inside) 10.0.0.6 1.2.3.5 netmask 255.255.255.255
HTH>
Community Member
Thanks Andrew,
Would I need this static NAT for the Exchange Server (10.0.0.5) rather than the Barracuda as I want the Exchange server to go out as 1.2.3.5?
I do have Global Nat set up using the Interface address for all inside hosts, but neither the Barracuda or Exchange Server use that address, they currently go out using the addresses I have set up in the Static NATs
Chris
1295
