Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Revert ASDM on ASA 5505 unit
I needed to upgrade my ASDM and ASA software on my firewall so I could access it via my Vista machine. I talked with a Cisco Tech and he pointed me to a could of links to down load 602 ASDM and 802 ASA bin files.
I did the ASDM first uploaded the bin file and configured it and the instrucstion said to log out and log back in. So I did that when I logged in it asked if I wanted to install the new software client which I did. I believe I should of done that because now when I login I get the following error. "Your ASA Image has a version number 7.2(2) which is not supported by ASDM 6.0(2). Please use Device Mgr 5.2(x)".
So my quesion is I've logged in via the console and the old ASDM image is still there so how can I put the old ASDM image back or install the ASA 8.02 image which I don't have on the unit yet.
TIA
1 ACCEPTED SOLUTION
Community Member
Re: Revert ASDM on ASA 5505 unit
Use this command:
asdm image flash:/asdm-522.bin
wr mem
The above command will tell ASA that it needs to use the ASDM image 5.2.2. Replace the filename if you have a different version of ASDM.
If you still face issues, run the command "show version" and check the second line of output to see which ASDM version does it show.
Community Member
Use this command:
wr mem
Community Member
when I type asdm image flash:/asdm-522.bin I get an error invalid character.
Community Member
Were you in the configuration mode when entering that command. Enter "config t" before you enter that command.
Community Member
Thanks that worked great.
Community Member
You can rate it if you found it of any help :-)
195
