Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Revisited, public servers, protocol and port restriction on outside interface
Hi folks,
Recently, I got help by Jouni restricting port access from the outside. Previously, I allowed IP, and ICMP from outside, and for example traceroute displayed the router names/addresses. After only allowing those ports open that correspond to internal servers, traceroute stopped working.
How can I get traceroute information, while locking down all irrelevant ports?
Best regards,
Peter
1 ACCEPTED SOLUTION
Super Bronze
You could start by checking if you have the following configurations
Issue the following command to see what inspections you have enabled
show run policy-map
Check if you have any "icmp" related inspections enabled. If not, then add the following to the same section where the rest of them are
inspect icmp error
inspect icmp
Also add the following statements to your ACL that is attached to your "outside" interface ACL
access-list OUTSIDE-IN line 1 remark Allow ICMP Return messages
access-list OUTSIDE-IN line 2 permit icmp any any unreachable
access-list OUTSIDE-IN line 3 permit icmp any any time-exceeded
Naturally your "outside" interface ACL was named differently so use that name instead. I inserted "line" numbers as I typically keep these rules at the very top of the ACL.
You might notice on the traceroutes taken from a host that the ASA will still not show up in the traceroute. There is a configuration that will allow the ASA to show up in traceroutes also but I dont typically enable it myself.
- Jouni
Super Bronze
show run policy-map
inspect icmp error
inspect icmp
- Jouni
Community Member
Thanks! Now it's working nicely!
Have a nice day :-)
Peter
114
