Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
route inside does not work on ASA 8.2(3), ASA cannot ping inside hosts
Hi Guys,
I have a problem on one our ASA seems to acting strange.
I have copy these routes below on ASA, and able to ping only 10.126.0.32.
route inside 10.126.0.10 255.225.255.255 10.20.3.1
route inside 10.126.0.30 255.225.255.255 10.20.3.1
route inside 10.126.0.31 255.225.255.255 10.20.3.1
route inside 10.126.0.32 255.225.255.255 10.20.3.1
route inside 10.126.0.140 255.225.255.255 10.20.3.1
route inside 10.126.0.141 255.225.255.255 10.20.3.1
route inside 10.126.0.142 255.225.255.255 10.20.3.1
When I saved the configuration and checking back on ASA running-configuration, none of above routes exists.
MYASA(config)# route inside 10.126.0.10 255.225.255.255 10.20.3.1
MYASA(config)# route inside 10.126.0.30 255.225.255.255 10.20.3.1
MYASA(config)# route inside 10.126.0.31 255.225.255.255 10.20.3.1
MYASA(config)# route inside 10.126.0.32 255.225.255.255 10.20.3.1
MYASA(config)# route inside 10.126.0.140 255.225.255.255 10.20.3.1
MYASA(config)# route inside 10.126.0.141 255.225.255.255 10.20.3.1
MYASA(config)# route inside 10.126.0.142 255.225.255.255 10.20.3.1
MYASA(config)# end
MYASA# show run | in route inside
route inside 10.0.0.0 255.0.0.0 10.20.3.1 1
route inside 10.96.0.0 255.224.0.0 10.20.3.1 1
route inside 10.96.0.10 255.225.255.255 10.20.3.1 1
route inside 10.96.0.30 255.225.255.255 10.20.3.1 1
route inside 10.96.0.31 255.225.255.255 10.20.3.1 1
route inside 10.96.0.32 255.225.255.255 10.20.3.1 1
route inside 10.96.0.140 255.225.255.255 10.20.3.1 1
route inside 10.96.0.141 255.225.255.255 10.20.3.1 1
route inside 10.96.0.142 255.225.255.255 10.20.3.1 1
route inside 10.100.1.61 255.255.255.255 10.20.3.1 1
route inside 10.101.20.112 255.255.255.255 10.0.0.254 1
route inside 10.101.20.113 255.255.255.255 10.0.0.254 1
route inside 10.101.20.114 255.255.255.255 10.0.0.254 1
route inside 10.101.20.115 255.255.255.255 10.0.0.254 1
route inside 10.101.20.201 255.255.255.255 10.0.0.254 1
route inside 10.101.20.202 255.255.255.255 10.0.0.254 1
route inside 10.101.20.204 255.255.255.255 10.0.0.254 1
route inside 10.101.20.205 255.255.255.255 10.0.0.254 1
route inside 10.101.22.22 255.255.255.255 10.20.3.1 1
route inside 10.101.24.100 255.255.255.255 10.0.0.254 1
route inside 10.101.24.101 255.255.255.255 10.0.0.254 1
route inside 10.101.25.0 255.255.255.0 10.20.3.1 1
route inside 10.126.0.32 255.255.255.255 10.20.3.1 1
route inside 67.215.65.132 255.255.255.255 10.20.3.1 1
route inside 192.168.1.3 255.255.255.255 10.0.0.254 1
route inside 192.168.1.4 255.255.255.255 10.0.0.254 1
route inside 192.168.151.0 255.255.255.0 10.20.3.1 1
route inside 192.168.151.48 255.255.255.240 10.0.0.254 1
route inside 205.210.235.0 255.255.255.0 10.0.0.254 1
route inside 205.210.236.0 255.255.255.0 10.20.3.1 1
route inside 205.210.237.0 255.255.255.0 10.0.0.254 1
route inside 205.210.238.0 255.255.255.0 10.0.0.254 1
route inside 205.210.239.0 255.255.255.0 10.0.0.254 1
route inside 205.210.240.0 255.255.255.0 10.0.0.254 1
route inside 205.210.241.0 255.255.255.0 10.0.0.254 1
MYASA#
It maybe a bug on the ASA?
Rizwan Rafeek
Hi,Can you give me the "show
Can you give me the "show route" and "show ip" from the ASA device ?
This route is actually showing up:-
Thanks and Regards,
Vibhor Amrodia
Hi Vibhor, Well, problem is
Hi Vibhor,
Well, problem is resolved from Cisco Tech support, it boiled down a bug.
"route inside 10.126.0.32 255.225.255.255 10.20.3.1", this route already existed, and yet it only one route shows up out of 7 copied, that is a bug.
Thanks for your reply.
Rizwan Rafeek.
69
