Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Routing based on destination IP and traffic type
Is it possible to route traffic based on the destination IP and the type of traffic?
ASA5512
Software 9.2.1
We have an ASA 5512 that is used as a VPN termination point. Our employees connect from one of our customer sites to this VPN point. The customer also hosts services on the same IP address that our employees use to access our VPN on.
What I want to do is to use a different route for certain traffic to take to get to these other services provide by our customer, for instance they offer an FTP site and I want to use a different route to get our internal users to this FTP site. Is this possible to achieve?
Any help would be greatly appreciated.
Murray
Everyone's tags (1)
1 ACCEPTED SOLUTION
Technically speaking the ASA
Technically speaking the ASA doesn't do policy based routing.  However, you might be able to simulate something similar to PBR by using a combination of static routes and NAT.
If you describe your Network setup, ASA, and how the alternate route is connected to your customer, we might be able to help you better.
Please remember to select a correct answer and rate helpful posts
Please remember to rate and select a correct answer
1 REPLY
108
