Routing failed to locate next hop for icmp
Hi Everyone,
Below is the setup
ASA1----DMZ----SW1----DMZ----ASA2
ASA1# ping 192.168.2.51
Sending 5, 100-byte ICMP Echos to 192.168.2.51, timeout is 2 seconds:
Success rate is 0 percent (0/5)
ASA1 config
interface Vlan4
 nameif DMZ
 security-level 45
 ip address 192.168.1.171 255.255.255.
/ASA1#  sh run route
route DMZ 192.168.2.0 255.255.255.0 192.168.1.174 1
Switch config
interface FastEthernet1/0/3
 description Connection To ASA 5510
 switchport access vlan 5
 switchport mode access
 spanning-tree portfast
interface Vlan5
 ip address 192.168.2.50 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.171
ASA2  config
interface Ethernet0/1
 nameif vlan5
 security-level 10
 ip address 192.168.2.51 255.255.255.0
 sh run route
route vlan4 0.0.0.0 0.0.0.0 192.168.1.171 1
From ASA1 i can ping the IP 192.168.2.50 but not .51
Logs from ASA1
 %ASA-6-302020: Built outbound ICMP connection for faddr 192.168.2.51/0 gaddr 192.168.1.171/17688 laddr 192.168.1.171/17688
%ASA-6-302021: Teardown ICMP connection for faddr 192.168.2.51/0 gaddr 192.168.1.171/17688 laddr 192.168.1.171/17688
Logs from ASA2
%ASA-6-302020: Built inbound ICMP connection for faddr 192.168.1.171/17381 gaddr 192.168.2.51/0 laddr 192.168.2.51/0
%ASA-6-110003: Routing failed to locate next hop for icmp from vlan5:192.168.2.51/0 to vlan5:192.168.1.171/0
 %ASA-6-302021: Teardown ICMP connection for faddr 192.168.1.171/17381 gaddr 192.168.2.51/0 laddr 192.168.2.51/0
Need to know is this default behaviour?
or can i fix this?
Best Regards
Mahesh
2 ACCEPTED SOLUTIONS
VIP Green
From PC 10.0.0.10 you will be
From PC 10.0.0.10 you will be able to ping ASA2 interface connected to the DMZ because that is the ingress interface of the ICMP packet.  However if you also have an outside interface on ASA2, the outside interface can not be pinged by PC 10.0.0.10 because it is not the ingress interface of the ICMP packet. If you move PC 10.0.0.10 so that the ICMP packet will ingress the outside interface on ASA2 then you will be able to ping that outside interface but not the DMZ interface...
Hope I explained that well enough?
Please remember to select a correct answer and rate helpful posts
Please remember to rate and select a correct answer
Hall of Fame Super Silver
Mahesh,As Marius and Kazim
Mahesh,
As Marius and Kazim noted, one cannot generally ping an ASA interface other that the one via which the packet was received.
I'd say that's the bottom line root cause of your initial observation. Thus the answer to your question "is this default behavior?" is "yes, it is".
You introduced a good bit of artificial complexity with your single switch configuration having physical connections (Layer 1) VLANS (Layer 2) and IP interfaces (Layer 3) connected physically and logically to ASA2 - as well as with the static route you have on ASA1.
Mahesh,You're only showing us
Mahesh,
You're only showing us half the relevant information. We'd need to see where each subnet resides and what the interface addresses of both ASAs are.
Generally speaking a given subnet needs to be contiguous.
 Hi Marvin, ASA1 !interface
Hi Marvin,
ASA1
interface Vlan3
 nameif sales
 security-level 50
 ip address 10.12.12.1 255.255.255.0
interface Vlan4
 nameif DMZ
 security-level 45
 ip address 192.168.1.171 255.255.255.0
ASA2
interface Ethernet0/0
 nameif vlan4
 security-level 45
 ip address 192.168.1.173 255.255.255.0
 nameif vlan5
 security-level 55
So subnet 192.168.1.x reside in both ASAs
Also subnet 192.168.2.x reside in Switch and ASA2.
let me know if you need any other info.
Mahesh
So your pings from ASA1 to
So your pings from ASA1 to the VLAN 5 interface of ASA 2 fail with the log message that the routing fails. But pings to the switch's VLAN 5 interface pass.
I suspect the switch has a VLAN 4 interface also - is it 192.168.1.174 (the gateway defined on ASA1)? If so the pings to the switch's VLAN 5 interface do not transit ASA2. Instead the switch itself replies directly to ASA1.
 Hi Marvin,Yes switch has
Hi Marvin,
Yes switch has vlan 4 int with IP 192.168.1.174.
Switch has gateway IP 192.168.1.171.
From ASA1 i can ping switch SVI 192.168.0.50.
As i am seeing log messages generated in the ASA2 so do u agree ping to IP 192.168.2.51 reaches the ASA2?
MAhesh
Hi Mahesh,You will not be
Hi Mahesh,
You will not be able to ping the outside IP on the ASA from a host on the inside. Additionally, you cannot ping the inside ip address from a host on the outside. If you are trying to ping another device on the outside from a device on the inside, you can enable stateful icmp inspection.
According to your log,
where u are using highlighted address:
/ASA1#  sh run route
i think you need to use 192.168.1.173
but as Marvan mention below, you have mysterious configuration on switch also.
kazim
"Don't forget to rate, if post helpful"
 Hi Kazim,i did as per
Hi Kazim,
i did as per you
ASA1
route DMZ 192.168.2.0 255.255.255.0 192.168.1.173 1
after doing this i can not even ping 192.168.2.50
 ping 192.168.2.50
Sending 5, 100-byte ICMP Echos to 192.168.2.50, timeout is 2 seconds:
pri/act/ASA1# ping 192.168.2.173
Sending 5, 100-byte ICMP Echos to 192.168.2.173, timeout is 2 seconds:
MAhesh
ok, send your config,
ok, send your config, especially switch interfaces which are facing ASA on both sides and vlan 4 and 5 as well
regards,
kazim
 ASA1interface Ethernet0/3
ASA1
 description Connection to Switch
 switchport access vlan 4
interface Vlan4
 nameif DMZ
 security-level 45
ASA1#                  sh run route
Switch port connecting to ASA1
interface FastEthernet1/0/1
 description Connection To ASA 5505
Switch Ports connecting to ASA2
interface FastEthernet1/0/2
 description Connection To ASA 5510 Int Eth0/0
 description Connection To ASA 5510 Int Eth0/1
interface Vlan4
 ip address 192.168.1.174 255.255.255.0
interface Vlan5
default route of switch is points to ASA1
ASA2 ports connecting to Switch are below --
 nameif vlan4
 security-level 45
 nameif vlan5
 security-level 55
Default gateway of ASA2 is
                      sh run route
MAhesh
VIP Green
As already mentioned you will
As already mentioned you will not be able to ping another interface on the ASA other than the ingress interface, so you will never be able to ping VLAN5 interface on ASA2.  It is normal behavior that you will see the failed to locate next hop log message.  this is because the ICMP packet reaches ASA2 but ASA2 has security measures in place to prevent pinging across the ASA interfaces.
 Hi MArius,Thanks for
Hi MArius,
Thanks for answering the question.
For better understanding the firewalls i work at my  home lab on weekends.
So does it mean that if host is behind say inside interface of ASA1 which is 10.0.0.x then that host can not ping anyother interface IP of  ASA2?
Even though ASA2 is connected far in the network??
Setup is here
PC--10.0.0.10-------inside---ASA1----DMZ---SW---- DMZ ASA2
From PC i can ping the IP of Vlan 5 on switch 192.168.2.50 but
i can not ping IP 192.168.2.51 of ASA2 interface
So does your answer applies to this also?
Best regards
Mahesh
VIP Green
Mahesh,
 Hi Marvin,I was trying to
Hi Marvin,
I was trying to understand the Firewall world so i was testing these things at home.This helps me in my job where i work extensively on firewalls.
Now i understand things better after getting replies from you.
Best regards
Mahesh
 Hi Marius,You explained me
Hi Marius,
You explained me very well.
Many thanks
MAhesh
227
