Routing help
whiteford
we can't get onto any internet pages that start with 89.x.x.x because one of our remote office LAN's has been set up to use 89.x.x.x/8 so everything for that IP range is routed to that network through our PIX 515. Is there anything we can do just for the moment to get on these pages, then we can fix this public LAN address to be a private address scheme?
Fernando_Meza
Level 7
Level 7
Hi .. unfortunately you need to re-address the remote site's LAN .. to avoid these conflicts .. internal networks should use a private addressing in the ranges.
10.0.0.0 - 10.255.255.255
172.16.0.0 - 172.31.255.255
192.168.0.0 - 192.168.255.255
I hope it helps .. please rate it if it does !!!
