Routing issue in ASA 5510 OS 8.03
ISP terminated in Router , I have two internet segment IP address . from the both segment IP address assigned in ASA and it directly connected to router with seperate interfaces.
Default route add for outside interface, another interface dmz1 should be reachable from internet.I know two default route is not possible with tunnling. pl help or if not possible i need to use another firewall.
1 REPLY
Re: Routing issue in ASA 5510 OS 8.03
The easy way out is to keep it simple.
Only have 1 connection from router to ASA. Then route the 2 Public IP Network to your ASA Firewall.
You can then make use of these 2 Public IP Network in your ASA.
Default route everything to your ISP Router using that single link.
Hope this helps.
110
