routing outbound traffic to 2 interfaces on asa
given;
rtr1 connected to outside
rtr2 connected to dmz1
lan connected to inside
we wanted to achieve the ff;
-mail traffic to go to the OUTSIDE
-http traffic to go to the DMZ1
how can we achieve the above on ASA
Re: routing outbound traffic to 2 interfaces on asa
Hi Celso,
Cisco firewalls do not support PBR (Policy Based Routing). Technically, what you want to achieve is impossible since you dont have specific destinations. But if you have the IP addresses of your destinations (which you cant for smtp or www traffic), following is the workaround.
Following config will redirect mail traffic to outside and rest of the traffic including web to dmz1.
access-list smtp_nat_outbound permit ip insideipsubnet insidenetmask any eq smtp
nat (inside) 1 access-list smtp_nat_outbound
global (outside) 1 interface
nat (inside) 2 0 0
global (dmz1) 2 interface
route outside mailserver1ip 255.255.255.255 rtr1ip
route outside mailserver2ip 255.255.255.255 rtr1ip
route outside mailserver3ip 255.255.255.255 rtr1ip
route dmz1 0.0.0.0 0.0.0.0 rtr2ip
That make sense. Thanks a lot.
You are welcome.
105
