Routing Question with Cisco ASA 5505 with 2 "Active" WAN Connections
We currently have a Cisco ASA 5505 Security Plus.  I am looking to bring in a seperate circuit to handle our SIP trunks.  I am not talking about an active/standby or failover setup.  Can I achieve this with a simple route statement?  Here is some backgound...
Interfaces:
Inside (VLAN1) 192.168.1.1 (security = 100)
Outside (VLAN2) 50.50.50.2 (security = 0)
VoIP (VLAN3) 60.60.60.2 (security = 50)
Can I just add the 2nd route statement to redirect all traffic for my SIP provider's switch which is located at 99.99.99.99?
route outside 0.0.0.0 0.0.0.0 50.50.50.1 1
route voip 99.99.99.99 255.255.255.255 60.60.60.1 1
I suspect the answer is yes and that I possibly just trying to overthink this issue.
Todd -
  • Firewalling
1 ACCEPTED SOLUTION
Hi , Yes this possible , to
Hi ,
 Yes this possible , to route specific traffic via gateway . Ensure inspect sip is enabled on global policy for your SIP traffic .
Sandy
Hi ,
Sandy
Yes, it does.Thanks!!Todd -
Yes, it does.
Thanks!!
Todd -
60
