routing specific traffic to second isp
hi all,
please see my config file...currently all my inetnet traffic is passing from service provider 1. I will be getting another internet connection from the second service provider...both these lines will be terminated to a layer 2 switch...with one service provider in one vlan and the new connection in another vlan....and their will be trunk between the switch and my pix 525 version 7.0...i will create sub interfaces with associated vlan tags ips of each service provider...Now what i want is currently all my 10.60.0.0 255.255.0.0 internet traffic is routed to current service provider but i want one specific subnet i.e. 10.60.10.0 255.255.255.192 to have a different nat address from the new service provider range and all the internet traffic for this subnet shall go from the new service provider connection. How can i acheive this?
ai
1 REPLY
Re: routing specific traffic to second isp
The only way I can think of for you to be able to do this is by using context mode. If you had a Router instead of a switch connected you could do policy based routing which would work. Is the switch just being used as a layer 2 switch or does it have layer 3 capabilities?
109
