Rules are not functioning in ASA 5525 using AD_Agent 1.0.0.32.1
I am using ASA 5525 ver 8.6 using AD_Agent with above version. build 598. From time to time when I am creating new rule using AD-Agent (user name allow to URL using FQDN) it is not working, and I got the following error message in the event viewer:
Faulting application name: ADObserver.exe, version: 0.0.0.0, time stamp: 0x4e2f0425
Faulting module name: wbemprox.dll, version: 6.1.7600.16385, time stamp: 0x4a5bdb2f
Exception code: 0xc0000005
Fault offset: 0x0000333b
Faulting process id: 0x14f4
Faulting application start time: 0x01cf4ca8458a9e40
Faulting application path: C:\IBF\adObserver\ADObserver.exe
Faulting module path: C:\Windows\system32\wbem\wbemprox.dll
Report Id: e1d585f0-d8d8-11e3-938d-005056985b98
Only after reboot the AD_Agent server it is working fine.
I installed two AD_Agent servers, one is dedicated AD_Agent and the secondary is installed in the AD.
Any Idea please?
Reuven
Hall of Fame Super Silver
The symptoms look like a bug.
The symptoms look like a bug. I'd go straight to a TAC case to see if it's documented internally.
Cisco TAC will likely encourage you to migrate to CDA as it's the recommended product for use with IDFW since AD Agent was discontinued.
Hi Marvin, Thanks for
Hi Marvin,
Thanks for replying to my post. I upgraded to CDA as recomended and I have the same problem. AD's CPU is jump to 80% because of the CDA. I also increased the hello time in ASA to 120sec. This reduced the CPU a little but still it is high.
Reuven
50
