02-06-2012 11:13 PM - edited 03-11-2019 03:25 PM
I have created a site to site tunnel with range 10.x.x.x
Now i want to creat a site to site tunnel with same range range with same policies as created with first tunnel ,with other far end peer ip.
Will this creat a problem .
02-06-2012 11:54 PM
You meant that your side network is 10.x.x.x. ? If so, there wont be an issue.
Else if peer end network is 10.x.x.x, then how will you route?
02-07-2012 12:25 AM
Just to clear you.I am creating another site to site vpn with other client peer ip but with same lan range of my end and same authentication , encryption , same keys.
02-07-2012 06:53 AM
Nope,
It should cause a problem, you can use the same phase 1-2 parameters and pre-shared key. There is no issue.
Mike Rojas
02-07-2012 11:48 PM
Hi Maykol,
Can be clear me regarding the problems we are going to face.
02-08-2012 05:03 AM
This will not cause any issue.
02-08-2012 07:28 AM
Beg your pardon, thanks Ajay. No it WONT cause an issue. I misspelled there.
Mike
02-08-2012 07:54 PM
02-08-2012 07:54 PM
thanks
