Same security level interfaces with access lists
We have an ASA 5510 with 3 connections, outside, inside and point2point running version 8.2 without nat control. We need hosts on the inside interface to communicate to hosts on the point2point interface. When we use the same-security-traffic permit inter-interface all works fine but we need to limit host to host traffic so we think ACLs will be the solution. Is there a way to establish inter interface traffic without same-security-traffic permit inter-interface and use access-lists or use this global command with access lists?
Thanks for any help.
Jeff
1 REPLY
HiYes, as you were saying,
Yes, as you were saying, the best way is to configure the two interfaces with different security-levels and then use ACLs to restric the traffic.
53
