Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
same security level rules
I came across some interface on our firewall with same security level & also ACE corresponding to each of these interfaces.
I also found that "same security level command" has been enabled on the firewall.
Question:
If 2 interfaces with same level say 50 need to pass traffic between each other, do they still require rules with above command enabled?
If i remove the rules and test the traffic , would it allow traffic between these interfaces based on above command?
Please suggest.Thanks.
1 ACCEPTED SOLUTION
Bronze
Re: same security level rules
Without the command enabled, traffic WILL NOT pass between two segments with identical security levels even if access-lists are configured.
With the command enabled, traffic WILL pass between the segments but must be permitted via an access-list.
Bronze
If the interfaces are configured with identical security levels, you have the "same-security-traffic permit inter-interface" command enabled, and you are running 7.2 or later code, you'll need to have specific rules to pass traffic in each direction between the segments.
Community Member
that means even with this command, rules still have to be there.
Then what purpose does this command serve?
Thanks.
Bronze
137
