Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Same V-Lan communication between sites via Tunnel
We have two ASA 5505 installed on both sites. If I make a new V-lan on FW1 like V-Lan 100 and assign the IP range 192.168.10.1/24 and same V-lan I create on other site FW2 like V-lan 100 and not assigned any IP but I want the FW2 clent machine use the gateway 192.168.10.1 and it will directly communicate. Is it possible? Thanks
Re: Same V-Lan communication between sites via Tunnel
hi ray
as long as the traffic between the Firewalls if L3 then the vlan tag will be removed adn u will not keep the vlan end-to-end
clients on remote site need to use FW2 as gateway regardless witch interface they connect to that interface should be thier gateway to the other FW1
good luck
if helpful Rate
FW 1 int e0/3 V-lan 100 192.168.10.1/24
FW 2 int e0/4 V-lan 100
Here we are not using any L3 switch all both int are configured on FW itself. Now please explain which wud be the gateway from client or FW.
each host will use the inside firewall IP as defualt gateway in each in its site
cllients---FW1-----FW2---clients
clients behind FW1 will use FW1 as defualt gateway to go to FW2 and clients behind FW2 will use FW2 as defualt gateway
if helpful Rate
Thanks!! Do i need to make two seperate subnets and allow them by making access list. Thanks
Please advice??
ok simly make like
192.168.1.0/24--FW1---othersubnet--FW2--192.168.2.0/24...
Client Machine (192.168.10.3 GTW 192.168.10.1)---ASA Vlan 100 (Int e 0/2) (192.168.10.1)-----Tunnel-------ASA Vlan 100 (Int e0/2) Same Vlan 100----Clent Machine (192.168.10.4, GTW 192.168.10.1)
The below scenario I want, is it possible through Tunnel. thanks
Pls advice!!!
182
