sandwich ASA with contexts mode
we are trying to design a sandwich ASA with contexts mode.
we have a couple ASA 5505 with licences for context and failover.
we are thinking on Active-Pasive and two context:
internet --- ASA1andASA2 in failover Context 1 ---- DMZ  --- ASA1andASA2 in failover with NAT context 2  ---- LAN.
with 3 interfaces physic is possible? (beacuse probably is necesary to use one for failover and one for management)
no problem for use NAT on context 2?
no problems for use static routes?
can you give us your advice?. also if possible some link were we can found information about the configuration?.
kind regards.
Hi Bro
Yes, 3 physical interfaces on each FW will do just fine. This is what you're gonna do.
Step 1: Create 2 contexts CONTEXT1 and CONTEXT2
Step 2: CONTEXT1 OUTSIDE = ISP E0/0 |  CONTEXT1 INSIDE = DMZ E0/1 <-- NATs
Step 3: CONTEXT2 OUTSIDE = DMZ E0/0 | CONTEXT2 INSIDE = LAN E0/1 <-- No Nat Control (v8.2 and below)
Note: E0/2 on both FW will be used for Failover
Warm regards, Ramraj Sivagnanam Sivajanam Technical Specialist/Service Delivery Manager – Managed Service Department
 thread seems quite old
 thread seems quite old ,nevertheless I am just curious which 5505 that supports context mode,
I have not seen none yet.
198
