SDM connection lost when applying firewall rules
After adding new firewall rules on a Cisco 1801 and hitting 'Apply settings', the progress window will scroll for a short period before a dialog is displayed that reads:
"Connection lost.
SDM lost the connection to your router because of a communication error. SDM will shut down when you click the OK button.
Re-launch SDM to continue working. Enter the same URL you used to re-start SDM."
Upon re-starting SDM, the rules have not been applied. The behaviour is consistent. I am using SDM 2.5 and have tried SDM 2.4.x and multiple versions of the Java VM.
Any ideas why I am unable to apply the firewall settings?
Your help would be most appreciated.
C.
Silver
Re: SDM connection lost when applying firewall rules
The router that you are configuring must be using a Cisco IOS image that supports the Firewall feature set in order for you to be able to use Cisco Router and Security Device Manager (Cisco SDM) to configure a firewall on the router.
Refer the following url for more info on settinf firewall using SDM:
http://www.cisco.com/en/US/docs/routers/access/cisco_router_and_security_device_manager/25/software/user/guide/Fwall.html
Thanks smahbub,
In the past I have been able to apply the firewall settings without incident.
I think it might be relevant that when I click 'apply settings' the count of commands increases by approximately 100 every time. It started to error after the number of commands exceeded around 2500.
I thought that the included 32MB CF card might be too small so I upgraded to a 512MB but that didn't seem to make any difference.
C.
518
