Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Secure VPN Connection Terminated
Dear All,
I have configured remote access VPN on my ASA-5510 Firewall 8.4(2) using DynDNS as I do not have static IP addresses. Everything was working fine but now my users cannot access the VPN tunnel from outside. (No changes have been made on the Firewall since the last VPN setup, after which everything was working optimally).
Users are receiving the following error message:
Secure VPN connection terminated locally by the Client. Reason 412: the remote peer is no longer responding.
Also the Host name and IP address is changing properly and seems like there is no problem from Dyn DNS side.
I will highly appreciate if someone could help me on this.
Thanks.
Shaikhu
Community Member
2012|16:50:12|106015|168.187.137.179|52432|2.50.15.172|10000|Deny TCP (no connection) from 168.187.137.179/52432 to 2.50.15.172/10000 flags ACK on interface Outside
above logs are generated in ASDM when I tried connectiong to remote VPN using the client.
Community Member
Thanks Ajay Chauhan for fixing this problem for me.
407
