Seems routing issue
Can anyone tell me as i have I recently added an inside router to connect a second inside network to my PIX Firewall. Users between the Cisco Secure PIX Firewall and inside router can get to the Internet just fine, but they cannot talk to this new, inside network. Users on the new network can't get past the inside router.
Could you please tell me what might be the issue?
1 REPLY
Re: Seems routing issue
This issue does not sounds like a routing issue. You need to check the below:-
1) NAT from inside to new interface
2) NAT from new interface to Inside
3) Security level of new interface
4) As the security level of the new interface will be lower than the inside - you WILL need to write and ACL.
HTH>
95
