set connection tcp-mss using policy-map in ASA 7.x
Is it possible to set "connection tcpmss <value>" by using policy-map and not the global command "sysopt connection tcpmss 1400". Reason is that the sysopt feature is extremely usefull when using tunelling [vpn]. For other communication though you get to restrict the mss value, while you could use a higher value [i.e. 1460 for ethernet].
Regards.
Re: set connection tcp-mss using policy-map in ASA 7.x
The link does not describe how you set tcp-mss value (sysopt connection tcpmss) but how to "disable" the inpection tcp-mss feature....
What I wand to do, is "activate" the "sysopt connection tcpmss" only between certian source/destination and not globally....
http://www.cisco.com/en/US/docs/security/asa/asa71/command/reference/s8_711.html#wp1111044
1076
