You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
SFTP connection
Hi, on a Mac computer I am trying to connect from the datacenter to an external server using different SFTP applications and getting different errors e.g. connection reset by peer, connection reset, etc. It does work randomly with some PCs. The connection seems to work fine from the same Mac when located at a branch site connected over DMVPN. Any thoughts are welcome,
  • Firewalling
1 REPLY
SFTP connection
I found another discussion that might have provided the right answer.
https://supportforums.cisco.com/thread/233287
Yes, I am using a 6509 in the data center...
266
