Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
share document between DMZ and Inside zone
hello,
i want to share file between dmz and inside.
for this can i give route in ASA 5540.
Re: share document between DMZ and Inside zone
If the no nat-control command is configured and no NAT policy matches, an address rewrite is not performed and processing continues. The default is NAT control disabled (no nat-control command).
Does ASA5540 has any NAT form inside to DMZ?? If no nat, it will be simple.
Apply ACL at dmz interface to permit dmz file server ip to inside file server
Then add route OK
hello ihave no file server ok
i want to share my antivirus server from inside to installed antivirus ti dmz server system now tell me what i do for it ?
261
