Simple routing question on ASA
I have a web server on a dmz on the ASA called DMZ_Web on 172.24.0.95/24 and it needs to get to an IP on a vpn that's via a router on the inside interface. The remote address is 10.180.250.10 and the inside router is 192.168.9.1 I need to add a route on the ASA.
Would is look like this:
route inside 10.180.250.10 255.255.255.255 192.168.9.1
I assume it has to be the inside interface and not DMZ_Web as the router is on my LAN on the inside?
1 REPLY
Re: Simple routing question on ASA
yes you are right
123
