SIP call dropped packets
Hi all,
I've got a sip client that I know works fine (tested with another modem/firewall).
Since moving my access across to a new 1812 I can no longer hold up a SIP session.
The SIP device sits in a DMZ but according to the logs its still getting dropped packets.
.Aug 12 09:06:29.552: %FW-6-DROP_PKT: Dropping udp session xx.xxx.xxx.xxx:5060 xxx.xxx.xxx.xxx:5060 on zone-pair WAN-self class class-default due to  DROP action found in policy-map with ip ident 0
.Aug 12 09:06:42.633: %FW-6-LOG_SUMMARY: 5 packets were dropped from xxx.xxx.xxx.xxx:5060 => xxx.xxx.xxx.xxx:5060 (target:class)-(WAN-self:class-default)
.Aug 12 09:07:01.057: %FW-6-DROP_PKT: Dropping udp session xxx.xxx.xxx.xxx:5060 xxx.xxx.xxx.xxx:5060 on zone-pair WAN-self class class-default due to  DROP action found in policy-map with ip ident 0
Not sure why... not even shure why its looking at the WAN-self class ?
After around 2mins the call goes silent sender and receiver can not hear or speak to each other.
I've attached my current config.
let me know what other info you need, its driving me crazy.
Re: SIP call dropped packets
where is the connection initiated from is it initiated from inside or from internet
Connection is initiated from a internal machine in the DMZ vlan out to the Internet
277
