site to site issue
Hi All,
We have  site to site tunnel suddenly the tunnel got disconnected and we recieved error such as
IKE Peer: 196.25.48.3
     Type    : L2L             Role    : responder
    Rekey   :  yes             State   :  MM_ACTIVE_REKEY
    Rekey   :  no              State   :  MM_REKEY_DONE_H2
And after time  tunnel was up automotically.When confirmed to far end network admin no changes where made from there side.From our side no changes were made.
My question is there any other factors for tunnel down reason.
site to site issue
Should be related to SA life cycle  check both end if there is mismatch or very short duration is configured.
site to site issue
Hi Ajay
Now the tunnel is displaying as
    Rekey   : no              State   : MM_ACTIVE
But the problem is we are not able to connect some remote machine as checked phase i is up and we have allowed ip range on firewall and there is no log when excuted show connection command.
Can u please suggest some command to check where the problem is there.
site to site issue
I would suggest following-
1) check all parameters both end should be same for phase 1 and 2
2) check pfs setting if configured should be on both side also can be tested removing both end.
3) check crypto acl
4) show ipsec sa to check if some traffic going might be one way.
5) finally run the packet tracer command
packet-tracer input inside 1024  80
it will show you what is happening in packet flow.
Ajay
site to site issue
Hi Ajay,
Problem we are able to take remote of  one  machine But not able to take any another machine which are in same range.
when i excuted the command show crypto  ipsec sa encryped packets are increasing but decrypted packet remains same.
Is it problem is from far end?
site to site issue
yes might be pfs is on other side would suggest to take a look on remote .
site to site issue
Hi please suggest on above output
site to site issue
looks like dropped by crypto acl please paste the config then only i can suggest something.
site to site issue
Hi Ajay,
Issue is solved , there is some problem from far end.
site to site issue
Great
751
