Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Site to Site VPN between ASA5510 and Sonicwall TZ200
I have setup a site to site VPN between Cisco asa5510 and Sonicwall tz200, the tunnel established successfully, but there is no traffice crossing tunnel. everythi is ok on the Sonicwall side, but asa is somehow blocking all the inbound and outboud traffic. I'm using the ASDM and the backet tracer is giving: packet dropped, IPsec spoofing.
Your help and advise are greatly appreciated.
Basel.
Re: Site to Site VPN between ASA5510 and Sonicwall TZ200
When you are using the packet tracer are you tracing from the interface IP, if you do you will get the error you are experiencing.
Yes, you're right, I'm tracing from the interface IP, so how can I trace inbound\outbound to the VPN tunnel which setup on this interface?
Thanks.
Try pinging an address on either side of the VPN not the interface IP's.
Hello Basel,
How do you know the ASA is the L3 device dropping the traffic?
Can you share the show crypto ipsec sa peer x.x.x.x (IP address of the Sonic wall Public IP) output?
An ASP-drop capture will let us know if the ASA is dropping the traffic
cap asp type asp-drop all circular-buffer
Try to send some traffic over the VPN tunnel and do the following
show cap asp | include x.x.x.x (source IP address you used to source traffic over the VPN tunnel)
What do U get?
For more information about Core and Security Networking follow my website at http://laguiadelnetworking.com
Any question contact me at jcarvaja@laguiadelnetworking.com
Cheers,
Julio Carvajal Segura
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Thank you Julio,
I'm not that familier with this appliance, but I ran the command you have suggested in the global mode, and I did not get any output, nor error, I just got the prompt back.
I genreated a traffic from: 192.168.5.30 and ran the following:   show cap asp | include 192.168.5.30
and had no output.
Thanks.
Hello Basel,
The ASP capture also known as the Accelerated Security Path capture (ASP is the algorithm the ASA uses in order to allow or deny traffic based on the different rule policies set on it) will show us all of the packets being dropped by the ASA.
That being said as you run it with no output it means the ASA is not dropping any traffic related to that IP in that moment.
Do the following on the ASA
Fixup protocol icmp
managment-access inside
and then
ping inside x.x.x.x (Host on the other site of the tunnel)
What's the result?
Cheers,
Julio Carvajal
This command did not go through, I got the following:
asa# fixup protocal icmp
ERROR: % Invalid input detected at '^' marker.
asa# Fixup protocol icmp
Hello Basel,
You got to be on configuration terminal mode
config te
Cheers,
Julio Carvajal
Here is the output:
Sending 5, 100-byte ICMP Echos t
Success rate is 0 percent (0/5)
Did you enable ICMP inspection? Did you add the managment-access inside? Did you use ping inside x.x.x.x ?
Can you share the output of
show crypto IPSec sa
note: Hide the public IP addresses from the output
Cheers,
Julio Carvajal
Hi Julio,
Everything seems to be ok in this access list. I think this is a routing issue. It is just does not know where to send the packet back or where to reply.
Crypto map tag: XXXX_map, seq num: 7, local addr: x.x.x.x
   access-list XXXX_7_cryptomap permit ip x.x.x.x x.x.x.x x.x.
x.x x.x.x.x
   local ident (addr/mask/prot/port): (local network and subnet)
   remote ident (addr/mask/prot/port): (Remote network and subnet)
   current_peer: x.x.x.x
   #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
   #pkts decaps: 9122, #pkts decrypt: 9122, #pkts verify: 9122
   #pkts compressed: 0, #pkts decompressed: 0
   #pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
   #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
   #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
   #send errors: 0, #recv errors: 0
   local crypto endpt.: x.x.x.x, remote crypto endpt.: x.x.x.x
   path mtu 1500, ipsec overhead 58, media mtu 1500
   current outbound spi:
inbound esp sas:
   spi:
       transform: esp-des esp-md5-hmac none
       in use settings ={L2L, Tunnel, }
       slot: 0, conn_id: .., crypto-map: xxxx_map
       sa timing: remaining key lifetime (sec): 18731
       IV size: 8 bytes
       replay detection support: Y
outbound esp sas:
   spi:
       slot: 0, conn_id: 8849, crypto-map: xxxx_map
       sa timing: remaining key lifetime (sec): 18673
       IV size: 8 bytes
Hello Basel,
We can see packets being decrypted but no packets being encrypted.
What version are you runnning (If 8.2.5) can you reload the FW and let us know how it goes after rebooting it
Julio Carvajal
I'm pretty sure that this is a routing issue, since ASA is receiving the packet, and dropping it since it does not know where to return it to:
There is no route to the VPN tunnel in here:
asa# show run route
route Inside 172.16.21.0 255.255.255.0 192.168.0.205 1
route Inside 10.10.12.0 255.255.255.0 192.168.0.205 1
route Outside 172.16.21.0 255.255.255.0 192.168.0.1 2
route Outside 0.0.0.0 0.0.0.0 x.x.x.x
asa#
Non of them is a route to the site to site VPN.
Can you please let me know how I can add this route?
Since this device is being used for Internet browsing the following route exist to route to our ISP:  route Outside 0.0.0.0 0.0.0.0 x.x.x.x
So I need to add a route to the VPN and keep the internet traffic routed to our ISP.
By the way the asa version is 7.2
Your help is greatly appreciated.
Hello Basel,
This is incorrect as you do have a default route,
I will need more information (The running configuration) please send it to me
Also I will need to know the remote subnet IP address and local Ip address ( Is it 172.16.21.0 or 10.10.12.0)
Julio Carvajal
Could this NAT policy be the reason?
access-list Inside_nat0_outbound extended permit ip 192.168.0.0 255.255.0.0 172
16.149.0 255.255.255.0
192.168.0.0/16   is the local subnet
172.16.149.0/24  is the remote subnet
Hello Basel,
No,
That nat 0 is good
do you have?
nat (inside) 0 access-list inside_nat0_outbound ??
Julio Carvajal
yes it is there:
nat (Inside) 0 access-list Inside_nat0_outbound
Then You are good,
You possitive the Crypto ACL is fine?
Any ACL on the inside interface blocking the traffic?
Do the following
cap capin interface inside match ip any 172.16.149.0 255.255.255.0
Then try to access any host there and d o
show cap capin
show cap asp | include 172.16.149.x (The IP address you accessed or try to)
Julio Carvajal
Just to mention that both wan interfaces IPs on both ends are on the same subnet   /27 . Could that be an issue?
1074
