Slingbox port forwarding
Greetings -
Trying to access my slingbox from the internet. Unable to do so. I just want to make certain that my forwading looks good.
I miss anything essential from this snippet on my pix 501?
access-list SLINGBOX permit udp any interface outside eq 5001
access-list SLINGBOX permit tcp any interface outside eq 5001
static (inside,outside) tcp interface 5001 10.0.0.254 5001 netmask 255.255.255.255 0 0
static (inside,outside) udp interface 5001 10.0.0.254 5001 netmask 255.255.255.255 0 0
access-group SLINGBOX in interface outside
I assume this looks fine. If so my problem lies elsewhere ..
grc.com shows that port 5001 is open
Re: Slingbox port forwarding
Are you seeing the hitcount on the ACL being incremented?? Are you obtaining an ip address via dhcp for your Internet connection??
Actually Yes I am seeing a hit count when I run a show access-list command. That is why I was confused on it was not functioning as expected.
However I resolved this issue. I simply had to "reset" the Slingbox device. I was questioning myself on the access-list commands as I am a bit rusty - thus why I posted it to this forum where as the folks here have a more of a clue then I do ;)
Thanks for replying!
940
