Slow flow through between Inside and DMZ on a PIX
Hello everyone,
Here's my setup:
PIX-515E Release 6.3
3 physical interface: IN, OUT, DMZ
I have a problem about the flow through between a PC on the inside and a pc on the DMZ.
The flow between the 2 machines is about 60kB in one direction and about 500kB in another.
I tested with different cables RJ45, switch and PC but the result is the same.
When I put the 2 PCs on the inside I have a throughput of about 10MB fairly reasonable.
For me it just my PIX, you have already encountered this problem? Is there a parameter to be added to allow better flow between certain interface?
Thank you in advance for your answers.
Rémi
1 ACCEPTED SOLUTION
Re: Slow flow through between Inside and DMZ on a PIX
Remi,
Collect the output again and see if the counters increment.
If so may be try to change the setting to auto auto on both ends (switch and firewall) and see if the errors will go away.
sh int e0/0
do it for each interface and findout which interface is seeing errors.
-KS
Bronze
have you tested throughput between two
devices on the DMZ?
Thanks for your answer,
Yes I have tested throughput between two devices on the DMZ and the result is also correct (near 10MB)
If you have another idea..
Rémi
sh int | i errors
do any of them show errors?
-KS
Bronze
Have you checked speed and duplex settings are fixed 100mb full duplex on clients switch ports and pix interface ports.
Are there any errors on pix interface ports?
Paul McGowan
Capita IT Services
Sent From Blackberry
Yes, all interfaces are fixed 100mb full duplex and switch too.
But:
sh int | i errors
    0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
    2232467 input errors, 1616434 CRC, 0 frame, 0 overrun, 1616434 ignored, 0 abort
    260 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
Remi,
sh int e0/0
-KS
Yes the counters increment in mode 100full
But in settings mode "auto" on the inside and DMZ now it's OK!!
Many thanks, throughput are great now !!
240
