smtp out and h.323 in
Dear support,
I wonder whether you can help me with small configuration changes to my firewall ASA 5505.
What I want to achieve is this:
1)      I want to setup outgoing traffic for SMTP protocol to go out only from one IP address 10.1.5.4 no other traffic should be restricted and should go out as any if that is possible.
2)      We have a video conferencing device on the network, Polycom VSX7000e and I need to setup the firewall to pass the h.323 traffic to go to IP address 10.1.5.15
3) would you also be able to advise on a free syslog server where we can monitor the traffic on the firewall?
Thank you
Patrick Babic
Result of the command: "show running-config"
: Saved
ASA Version 8.2(2)
names
name 10.1.4.4 ctxsvr01
name 10.1.4.5 itsvr
name 10.1.4.10 unicornsvr
name 10.1.4.12 blbsvr
name 10.1.4.13 exchsvr
name 10.1.5.4 barracuda
name 10.1.5.15 video-conferencing-unit
name 192.168.1.5 ctxdmz
name 62.253.196.178 outside
name 62.253.196.179 remote-outside-179
name 62.253.196.180 webmail-outside-180
name 62.253.196.181 connect-outside-181
name 62.253.196.182 unicorn-outside-182
name 62.253.196.184 sirsi-outside-184
name 62.253.196.185 blb-outside-185
name 62.253.196.188 streaming-outside-188
name 62.253.196.189 video-conferencing-outside-189
name 82.111.186.146 sdt-rdc
name 150.147.68.20 sirsi-1
name 193.110.143.20 sirsi-2
name 10.1.5.16 streaming-unit
name 192.168.1.1 dmz
name 62.253.196.186 email-outside-186
name 62.253.196.187 Logmein-outside-187
interface Vlan1
nameif inside
security-level 100
ip address 10.1.5.1 255.255.0.0
ospf cost 10
interface Vlan3
nameif dmz
security-level 50
ip address dmz 255.255.255.0
ospf cost 10
interface Vlan12
nameif outside
security-level 0
ip address outside 255.255.255.240
ospf cost 10
interface Ethernet0/0
switchport access vlan 12
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
switchport access vlan 3
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
clock timezone GMT 0
dns server-group DefaultDNS
domain-name chathamhouse.org.uk
object-group network sirsi-support
network-object host sirsi-1
network-object host sirsi-2
object-group service backup-exec tcp
port-object eq 10000
port-object eq 3106
port-object eq 3527
port-object eq 6101
port-object eq 6103
port-object eq 6106
object-group service barracuda-8000 tcp
port-object eq 8000
object-group service blackberry-3101 tcp
port-object eq 3101
object-group service citrix-session-reliability-2598 tcp
port-object eq 2598
object-group service rdc-3389 tcp
port-object eq 3389
object-group service sql-1433 tcp
port-object eq 1433
object-group service streaming-1935 tcp
port-object eq 1935
object-group service video-streaming-tcp-udp tcp
port-object eq 3230
port-object eq 3231
port-object eq 3232
port-object eq 3233
port-object eq 3234
port-object eq 3235
object-group service rdp tcp
port-object eq 3389
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group network DM_INLINE_NETWORK_1
network-object host remote-outside-179
network-object host webmail-outside-180
object-group network DM_INLINE_NETWORK_2
network-object host unicorn-outside-182
network-object host email-outside-186
object-group service DM_INLINE_TCP_1 tcp
port-object eq h323
group-object video-streaming-tcp-udp
group-object streaming-1935
object-group service Reuters udp
port-object eq 10202
port-object eq 10302
port-object eq 9876
access-list outside_access_in extended permit tcp any any object-group rdc-3389
access-list outside_access_in extended permit tcp any host blbsvr object-group blackberry-3101
access-list outside_access_in extended permit tcp any object-group DM_INLINE_NETWORK_1 eq https
access-list outside_access_in extended permit tcp any host blbsvr eq ssh
access-list outside_access_in extended permit tcp any host ctxdmz eq ftp
access-list outside_access_in extended permit tcp any object-group DM_INLINE_NETWORK_2 eq www
access-list outside_access_in extended permit tcp any host outside eq smtp
access-list outside_access_in remark SQL
access-list outside_access_in extended permit tcp any any object-group sql-1433
access-list outside_access_in extended permit tcp any host video-conferencing-outside-189 object-group DM_INLINE_TCP_1
access-list outside_access_in extended permit tcp any any object-group backup-exec
access-list outside_access_in extended permit udp any any object-group Reuters
access-list outside_access_in extended permit tcp any host streaming-unit eq nntp
access-list dmz_access_in extended permit ip any any
access-list dmz_access_in extended permit tcp host ctxdmz 10.1.0.0 255.255.0.0 object-group rdp
access-list dmz_access_in extended permit tcp host ctxdmz 10.1.0.0 255.255.0.0 eq www
access-list dmz_access_in extended permit tcp host ctxdmz 10.1.0.0 255.255.0.0 eq citrix-ica
access-list dmz_access_in extended permit tcp host ctxdmz 10.1.0.0 255.255.0.0 object-group citrix-session-reliability-2598
access-list dmz_access_in extended permit object-group TCPUDP host ctxdmz 10.1.0.0 255.255.0.0 eq domain
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit ip 10.1.0.0 255.255.0.0 host ctxdmz
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu dmz 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any dmz
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
nat (dmz) 1 0.0.0.0 0.0.0.0
static (dmz,outside) tcp remote-outside-179 https ctxdmz https netmask 255.255.255.255
static (inside,outside) tcp connect-outside-181 3389 itsvr 3389 netmask 255.255.255.255
static (inside,outside) tcp interface smtp barracuda smtp netmask 255.255.255.255
static (inside,outside) tcp interface ssh barracuda ssh netmask 255.255.255.255
static (inside,outside) tcp blb-outside-185 3101 blbsvr 3101 netmask 255.255.255.255
static (inside,outside) tcp unicorn-outside-182 www unicornsvr www netmask 255.255.255.255
static (inside,outside) tcp streaming-outside-188 1935 streaming-unit 1935 netmask 255.255.255.255
static (inside,outside) tcp webmail-outside-180 https exchsvr https netmask 255.255.255.255
static (inside,outside) tcp email-outside-186 www exchsvr www netmask 255.255.255.255
static (inside,outside) tcp Logmein-outside-187 nntp streaming-unit nntp netmask 255.255.255.255
static (inside,outside) tcp sirsi-outside-184 3389 unicornsvr 3389 netmask 255.255.255.255
static (inside,outside) tcp video-conferencing-outside-189 h323 video-conferencing-unit h323 netmask 255.255.255.255
static (dmz,inside) 192.168.1.0 192.168.1.0 netmask 255.255.255.0
static (inside,dmz) 10.1.0.0 10.1.0.0 netmask 255.255.0.0
access-group inside_access_in in interface inside
access-group dmz_access_in in interface dmz
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 62.253.196.177 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 10.1.0.0 255.255.0.0 inside
http sdt-rdc 255.255.255.255 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet 10.1.0.0 255.255.0.0 inside
telnet timeout 5
ssh 10.1.0.0 255.255.0.0 inside
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
smtp-server 10.1.4.13
prompt hostname context
Cryptochecksum:87d40342041882f3775cd7f31750f0fc
: end
1 ACCEPTED SOLUTION
Re: smtp out and h.323 in
This is not TAC. Just forum between Cisco networking professionals.
Please open a TAC case if you require assistance from TAC engineer.
1) For your SMTP requirement:
access-list inside_access_in line 1 extended permit tcp host 10.1.5.4 any eq 25
access-list inside_access_in line 2 extended deny tcp any any eq 25
2) You would need to know what protocol/port Polycom uses for the H323 connection. You have configured just TCP port redirection for TCP/1720. Moreover, there are limitation with static port address translation, so you might want to change the following static statement to 1:1 NAT:
Change from:
To:
static (inside,outside) video-conferencing-outside-189  video-conferencing-unit netmask 255.255.255.255
How is it failing? Does call signaling work? No video? No audio?
3) I believe there is free version of Kiwi Syslog server.
Hope that helps.
thanks for the advise,
1) I have setup the smtp and it works
2) my colleague who is dealing with VC is not in today ( holiday ) so once he comes back we will be testing it.
3) I will check the Kiwi server
can you please keep the ticket open until we test the VC?
thanks
Patrick
334
