Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
source based PBR issue
I come up with requirement of source based  (IP) PBR on my firewall ASA 5510. My requirement is as follows
We have a Datacenter and a branch connected with eachother through IPSEC and MPLS. IPSEC is primary connection and MPLS is secondary one.
We have one more location where our webex servcie hosted. Both DC and branch will communicate with WEBEX server through internet. Offlate i am facing intermittent disconnection with internet connecitivity and ISP no longer giving proper response. At the same time MPLS works without any issue. So want to route my webex traffic trhough DC via MPLS and then from there via internet to webex server. I am little bit scepticle about the reverse route as IPSEC is the primary connection between DC and Branch. How can i write PBR for the return traffic from webex server to passthrough MPLS to branch.
I highly appreciate the response
1 REPLY
Hello Vamsi
As far as your requirement is concern you need to route your webex traffic through MPLS and other traffic through your IPSEC interface.
This is clear case of policy based routing which is not supported on firewall .
It can be done as a work around which is not cisco recommends you can go through the below link for further details.
https://supportforums.cisco.com/docs/DOC-13015
regards
Gaurav
129
