split tunnel problem
I'm trying to enable split tunnelling but what appears to happen at the moment is that i can access the vpn.
at that point i still have external internet access.
When i actually connect to the server then i lose internet access.
i've attached my config file to see if someone can spot what is probably an obvious mistake.
thanks in advance
suzanne
1 ACCEPTED SOLUTION
Green
Re: split tunnel problem
access-list nonat permit ip
nat (inside) 0 access-list nonat
One other thing I noticed is that the vpn pool is part of the inside network. It is not advised to have this configuration. The vpn pool should have a completely different subnet. For example...
ip local pool george4vpn 192.168.20.200-192.168.20.230
access-list nonat permit ip 192.168.10.0 255.255.255.0 192.168.20.0 255.255.255.0
Also, if you want split tunnel then acl 120 should read...
access-list 120 permit ip 192.168.10.0 255.255.255.0 192.168.20.0 255.255.255.0
Hope this helps. Please rate helpful posts.
I think this isn't a split tunnel problem.
The issue is I can bring up a webpage but not access remote desktop or any other server services. When I look at the vpn stats on the remote connection there are none received although plenty are being sent.
Suzanne
Green
Thanks for the help, and my apologies for taking so long to say thank you. It was all resolved last week.
Can I ask why you say the vpn pool should be on a completely different subnet? It works but I'm curious as to why this would be necessary.
Suzanne
Suzanne, the pool needs to be unique so the firewall knows were to route the packets, you cannot have two of the identical subnets in existance within a network ~ bad things will happen.
104
