Split tunnel stops working after power failure on pix 501
I have a very strange problem. One of my users pulled the power out of the cisco pix 501. It powered off and came back up again. Users can still connect to the vpn but split tunneling is no longer enabled.
I have checked the entries and they are all still there and don't appear to be corrupted. I even tried re-adding the split tunnel related ones. It makes no difference.
Does anyone have any ideas how to remedy this ?
Thanks in advance
Suzanne
Silver
Re: Split tunnel stops working after power failure on pix 501
Can you post a sanitized config?
hi
i reapplied the settings and its working again, very strange..
115
