Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Split tunneling
Hi Expert,
I have a requirement which asks for tunneling all traffic from vpn client except for 3 public IP addresses. The Client VPN terminates on ASA 5510 version 7.2(4)
The configuration I tried are as below:
access-list exclude_1 extended permit ip 10.24.30.0 255.255.255.0 host 202.3.10.210
access-list exclude_1 extended permit ip 10.24.30.0 255.255.255.0 host 202.3.10.222
access-list exclude_1 extended permit ip 10.24.30.0 255.255.255.0 host 203.2.190.222
group-policy BartterPolicy attributes
wins-server value 10.1.0.63 10.3.0.1
dns-server value 10.1.0.63 10.3.0.1
vpn-tunnel-protocol IPSec
split-tunnel-policy excludespecified
split-tunnel-network-list value exclude_1
but from the stats - route details it stills shows 0.0.0.0 in the secure routes which means tunnel all traffic.
Any idea why this is happening. Thanks in advance.
Re: Split tunneling
What version of code are you running?
try a different approach:-
split-tunnel-policy tunnelspecified
access-list exclude_1 extended deny ip 10.24.30.0 255.255.255.0 host 202.3.10.210
access-list exclude_1 extended deny ip 10.24.30.0 255.255.255.0 host 202.3.10.222
access-list exclude_1 extended deny ip 10.24.30.0 255.255.255.0 host 203.2.190.222
access-list exclude_1 extended permit ip 10.24.30.0 255.255.255.0 any
HTH>
Community Member
Re: Split tunneling
No luck. with this all internal access is not working but Internet access works with any restriction.
Re: Split tunneling
post the relevant config for review.
Community Member
Re: Split tunneling
the checkbox on the client for allow local lan needs to be checked.
Community Member
Re: Split tunneling
Under splittunneling access list try adding the IP of the gateway on the remote client side
Also enable split dns
161
