Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Sporadic SMTP Connection Drops ASA 5505
My company is having some issues with receiving emails to our Mdaemon Email server. I had the Mdaemon techs take a look at what's going on and they say that our ASA5505 is dropping the connections. Now this is not happening all the time but sporadically it does. I need to get this fixed ASAP. I need some help. Our IOS version is 7.2(2). Probably a little dated.
Re: Sporadic SMTP Connection Drops ASA 5505
Pls. issue sh run policy-map
and see if you have inspect esmtp enabled. If so, pls. disable and see if the problem goes away.
Community Member
It is enabled.. How do you disable it. I'm new with Cisco firewalls. Can this be disabled with users on the system? If this doesn't work, how to re-enable?
196
