ssh fail to work
Hi all,
My ssh on my cisco asa 5510 fail to work.
I have enabled the following but my ssh client fail to connect to the firewall from my office network(connected to firewall inside interface).
aaa authentication ssh console LOCAL
ssh 10.0.0.0 255.0.0.0 inside
ssh timeout 5
I have also enable a rsa key and enable using ssh version 1 and 2
Pls advise. Thks in advance.
Re: ssh fail to work
Are you able to telnet on port 22?
Try to use a different SSH client as sometimes it could be problem with the client itself.
Hi Jennifer,
I am unable to telnet to the firewall on port 22
Hello Don
Would you please paste the result of the command show asp table socket?
Cheers
Mike
Mike
Hi maykol,
I am using asa version 7.0
There is no "socket" option  for "show asp table"
The following options are available for "show asp table"
arp          Show ASP ARP table
  classify     Show ASP classifier tables
  interfaces   Show ASP interfaces tables
  routing      Show ASP route tables
  vpn-context  Show ASP VPN context tables
Hello Don,
I hope you are doing great, would you please put the debug ssh 255 and try again?
Cheers
Mike
Mike
Hi Don,
You can also setup a packet capture to confirm the SSH connection is actually reaching the inside interface of the firewall:
access-list capin permit tcp host host eq 22
capture capin access-list capin interface inside
show capture capin
If you see traffic reaching the firewall in the capture, try removing all SSH commands and re-adding them. Also, double check the syslogs that are generated at the time.The 7.0 version code is extremely old at this point, so you may also be running into a bug. Upgrading to 7.2(5) or 8.0(5) may help you overcome this problem as well.
If you don't see traffic reaching the firewall, double check network connectivity between your client and the firewall.
Hope that helps.
-Mike
636
