SSH issue on inside interface.
I cant ssh to inside interface access of ASA5505 firewall wihile ASDM and telnet are working. I have opened SSH access along with telnet and ASDM.
I can ssh to outside interface. Its very wied problem that SSH on inside interface is not working.
Below is the oconfiguration of my ASA5505 firewall. Any solution please
ASA Version 8.3(2)4
hostname MEL-ASA-01
domain-name xxxxxxxxxxxxxx
interface Vlan1
nameif inside
security-level 100
ip address 10.0.16.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address xxxxxxxxxx 255.255.255.252
interface Vlan50
shutdown
no forward interface Vlan1
nameif dmz
security-level 50
ip address 10.0.112.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
switchport access vlan 50
interface Ethernet0/7
boot system disk0:/asa832-4-k8.bin
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
dns server-group DefaultDNS
access-list Inside_noNAT extended permit ip any object-group Edn_LAN
access-list Inside_noNAT extended permit ip any object VPN_Dialup
access-list Inside_noNAT extended permit ip object-group Edn_LAN interface inside
access-list Inside_OUT extended permit tcp object-group email_allowed_hosts object edn-exc-01 eq smtp
access-list Inside_OUT extended deny tcp any any eq smtp
access-list Inside_OUT extended permit ip any any
access-list Outside_IN extended permit icmp any any echo-reply
access-list Edinburgh_tun_acl extended permit ip object MEL_Lan object-group Edn_LAN
access-list Edinburgh_tun_acl extended permit ip object MEL_Lan object VPN_Dialup
pager lines 24
logging enable
logging trap critical
logging history critical
logging asdm warnings
mtu inside 1500
mtu outside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-647.bin
no asdm history enable
arp timeout 14400
nat (inside,any) source static any any destination static Edn_LAN Edn_LAN
nat (inside,any) source static any any destination static VPN_Dialup VPN_Dialup
object network obj_any
nat (inside,outside) dynamic interface
access-group Inside_OUT in interface inside
access-group Outside_IN in interface outside
route outside 0.0.0.0 0.0.0.0 xx.xx.xx.xx 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http Edn_Svr 255.255.254.0 inside
http 10.0.16.0 255.255.255.0 inside
http xx.xx.xx.xx 255.255.255.224 outside
http Edn_Data 255.255.252.0 inside
snmp-server host inside 10.0.0.32 community ***** version 2c
snmp-server host inside 10.0.0.40 community ***** version 2c
snmp-server location Amsterdam
snmp-server contact
ts@xxxxxxxxxxxxxx
snmp-server enable traps snmp authentication linkup linkdown coldstart
snmp-server enable traps syslog
snmp-server enable traps ipsec start stop
snmp-server enable traps entity config-change fru-insert fru-remove
snmp-server enable traps remote-access session-threshold-exceeded
telnet Edn_Data 255.255.252.0 inside
telnet 10.0.16.0 255.255.255.0 inside
telnet Edn_Svr 255.255.254.0 inside
telnet timeout 5
ssh Edn_Svr 255.255.254.0 inside
ssh 10.0.16.0 255.255.255.0 inside
ssh Edn_Data 255.255.252.0 inside
ssh 172.16.1.16 255.255.255.255 inside
ssh edn-pix2 255.255.255.255 outside
ssh 94.175.211.224 255.255.255.224 outside
ssh timeout 5
ssh version 2
console timeout 0
management-access inside
dhcpd option 150 ip 172.17.0.10
dhcpd address 10.0.16.128-10.0.16.192 inside
dhcpd dns 10.0.16.11 10.0.0.11 interface inside
dhcpd wins 10.0.0.11 10.0.0.12 interface inside
dhcpd lease 86400 interface inside
dhcpd ping_timeout 750 interface inside
dhcpd domain axiossystems.com interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 10.0.0.1 source outside prefer
webvpn
username xxxxx password xxxxxxxxxx encrypted privilege 15
tunnel-group xxxxxxxxxxxxx type ipsec-l2l
tunnel-group xxxxxxxxx ipsec-attributes
pre-shared-key *****
peer-id-validate cert
tunnel-group xxx type ipsec-l2l
tunnel-group xxxxxxxxxxxxx ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:6xxxxxxxxxxxxxxxxxxxxxxxxxx
: end
Super Bronze
Very strange that it would work from "outside" and not "inside".
You can use the command
show asp table socket
To confirm if the ASA is listening on port TCP/22 on the "inside" interface.
Otherwise I would probably suggest monitoring the SSH Connection attempt through the ASDM to determine what is the cause of the problem.
I assume you are trying to connect from the "inside" network?
- Jouni
Hi Jouni Fross
Yes I am trying to access on inside interface. Please find below the output of command. I am not sure how can I monitor via ASDM. can you please help
mahmood
Protocol  Socket    Local Address               Foreign Address         State
SSL       0003de0f  10.0.16.1:443               0.0.0.0:*               LISTEN
SSL       000507cf  xxxxxxxxxx:443          0.0.0.0:*               LISTEN
TCP       000934ff  10.0.16.1:22                0.0.0.0:*               LISTEN
TCP       000c9daf  xxxxxxxxxx.22:22           0.0.0.0:*               LISTEN
TCP       01d755bf  10.0.16.1:23                0.0.0.0:*               LISTEN
SSL       02e95178  10.0.16.1:443               172.16.1.16:50078       ESTAB
SSL       02ed4e28  10.0.16.1:443               172.16.1.16:50080       ESTAB
TCP       031061d8  10.0.16.1:23                172.16.1.16:51609       ESTAB
Super Bronze
Well first of I would look at the monitor logging section while attempting the SSH connection.
If that doesnt help then you always have the option to use "debug ssh" and monitor the output through ASDM or a Telnet management connection.
The above output would seem to indicate that the ASA is listening on the port TCP/22 on the "inside" interface.
Are you just getting timeout for the SSH connection or are you getting any prompts?
- Jouni
I have run SSH DEBUG command but I am not getting any output on prompt.
I am not getting any log on ASDM as well.
I am getting the following error when trying ssh to inside interface
The session used to hang up for 2-3 minutes and then returned the following error
"Putty fatal Error              Network Error: Software caused connection abort  "
I understand that you are able to connect via outside, but try by regenerating the crypto key. Just a thought .
Thx
MS
693
