Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
SSH through management interface
I'm using Cisco Pix 515E, 8.0(3).
I configured remote access VPN. I allowed management-access interface - inside. Then I allowed ssh:
ssh 0.0.0.0 0.0.0.0 inside
But I can't connect with SSH on pix inside interface.
I saw release notes on 8.0(3), where this issue is marked like corrected.
But for me this doesn't work.
Is there any special configuration with ssh though management interface through VPN? Or do you have the same experience?
Many thanks,
Vladislav
Gold
Re: SSH through management interface
have you verified that ssh works from the local LAN?
Community Member
Yes ssh works correctly from local.
Gold
can you ping the inside interface?
do you have the command sysopt connection permit-vpn?
if not, are you allowing the traffic via your outside acl?
Community Member
Yes, I can ping inside interface even through VPN. When I make telnet 22 it opens black window. When I use putty, it freezes on black window, too, but doesn't write, that connection refused or sothing like this.
I have permitted sysopt connection permit-vpn.
137
