Static Entry - ASA
OSPF is running between L3Switch and ASA but still need static entry on L3Switch to forward traffic to ASA.
ip route 0.0.0.0 0.0.0.0 192.168.1.10
Can someone explain why?
  • Firewalling
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: Static Entry - ASA
Nasr
"On ASA I have default route like this
ip route 0.0.0.0 0.0.0.0 80.11.22.33 ( ISP Router)
and internal routing via OSPF."
But have you told the ASA to send this default route to the L3 switch with the default-information originate command -
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/d2_72.html#wp1773168
Jon
Nasr
Have you configured the ASA to generate a default route and send it to the L3 switch ?
If not then you would indeed need a static route on the L3 switch assuming the ASA is for Internet connectivity.
Jon
I understand its needed on ASA to add static route for ISP Router to send all traffic on internet.
but dont understand why I need static route on L3Switch if ospf is running.
Nasr
Jon
Thanks a Lot, I got what you mean.
No problem, glad to help.
Jon
124
