STATIC NAT help..
If we set tcp max connection to 0 which means no limits on the connection, over 65535 simultaneous connections can be made through the static nat?
Re: STATIC NAT help..
Hello Panoratech ...
On which hardware ? ASA ? PIX ? FWSM ?
A server with more than 65K simultaneous connections ... it would be really impressing!
jF
it's asa.
108
